engine cutting out
engine cutting out
When my car is cold just after start up on idle my engine cuts out when I give it anything over 2/3 throttle. I'm thinking I just need to get the link computer and dial the low rpm mixture a little leaner. Do you guys have any renforcement on that idea or is it a diffrent problem. Thanks for the help. <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Typically cold-engine stumbles are caused by too lean of a mixture. Does it stumble if the engine's warm? If not, then I would tend to think there's a temp-sensor issue, like the air-temp or engine-temp sensor. Please verify that you have the air-temp sensor plugged in to the #1 & #4 terminals on the stock AFM plug.
