Steel control arms to replace aluminum arms
What was your issue with the castor blocks? I ask because I went with steel arm castor blocks with Weltmeister poly bushings and after only 6 track days, they are pretty torn up.
I'm planning to go with racer's edge spherical bearings next but wanted to know what you're running.
http://www.paragon-products.com/Cont....153d-race.htm
"... includes 2 steel arms, the front Racers Edge Delrin bushings and the rear Weltmeister polygraphite bushings."
Caster blocks:
http://www.paragon-products.com/Cont...77.407.169.htm
The only issue with the caster blocks is that they are $72 each.
Control arm kit:
Caster blocks:
Caster blocks:
Yeah. That's what I'm talking about and already have on the car. Doesn't work for heavy track usage.
$140 for a set of castor blocks + $20 for bushings isn't bad, in my opinion. If you're not tracking the car heavily, they work well and are affordable.
The racer's edge spherical bearings I'm moving to are $380 a set.
I don't like spericals in the rear control arm pockets as the inner bushing mount nuts are spot welded an break easily due to the harsh vibrations. They are a nighmare to repair. I have not tried Delrin in the rear bushings. Does anyone have experience with them?
It may not have worked for you, but it works fine for me. So far, I have about 20 track days on the setup, mostly PCA club racing, with no issues and no visible wear.
I share that concern. I don't know of a delrin solution for the rear bushing on early a-arms. Would love to find one.
The alloy arm caster pin is 19mm diameter (inside arm) and 18mm diameter that inserts into the block. I'm going to build a set of arms that include the caster pin mechanism, although I have seen many factory pin tab locations that all point down (zero caster) anyways. Having that 18mm dia. pin opens up many caster block options.
Stock turbo power and weight with 245/275 tires and 550 lb springs.
I am also going to make them accept replaceable 17mm and 19mm Ball-joints but I'm still on the fence weather I will make a U-joint adapter bracket that allows for both the Early and Late offsets like the RX7 arms I modded or if I'll machine each set accordingly...Input?
![](https://i94.photobucket.com/albums/l96/xschop/Image011-7.jpg)
![](https://i94.photobucket.com/albums/l96/xschop/Image013-5.jpg)
I also have these A arms in my shop. (And a hood on my roof. lol) But.. Those ball joints are really hanging out there. The RX7 Arms themselves are truly nice forged pieces.
