Engine Troubles... (oil coolant mix, overheating)
How long did the car stand between the head gasket failure and the new head gasket install?
You might be surprised how much coolant can drain down the oil galleries while the engine just sits with a bad hg. I was convinced I had a coolant to oil leak, but it turned out to take several oil flushes to get rid of the coolant that had sat in the oil pan for a few months before my hg repair.
Try draining and flushing with new oil one or twice, and carefully bleeding the coolant system before trying anything else.
Car stood a while between head gasket failure and new head gasket install. Head gasket failed (well I thought it did, now I'm not sure) November 2010-ish, Finally took the head off around May this year, put the head back on around a month ago.
The car is in RI and I live in Boston, so that would explain the time between everything...
BTW I installed the steam vent kit from lindsey also, and bled many times but I suggest that perhaps the coolant level was dropping enough to add more air to the system.
Maybe I will try new oil a couple times but I'm not sure if that will solve my coolant loss or overheating. It might just be better for me to reseal the oil cooler before wasting more money on oil. just in case..
Does anyone know what the red area of the temp gauge on the dash represents? I also installed a new temp sensor before that fateful drive.
http://www.google.com/products/catal...ed=0CF4Q8wIwAg
This is the kit i own. You can youtube how to use it but its fairly straight forward
