Seized rear hatch pin
I wanted to adjust my hatch pins to tighten it down and address that last niggling little 'tapping' sound as I go over bumps etc.
The first side was easy. Loosened the nut, wound the latch pin in slightly, and retightened. -That one's perfect now.
On the second side however, I can loosen the nut, but the pin doesn't want to budge.
Anyone got any hints/tips/things to check?
Cheers!
Keith
Cheers!
Keith
A touch of rust or something maybe? Spray with Kroil and wait and see if it breaks loose. Tap tap on it a little bit after with a small rubber mallett. Not too much help - sorry.
I had a similar problem... the pin eventually broke off I wound up replacing both pins with the stainless ones from Rennbay and replacing the weird square rubber-covered nut thingy on the one side with a washer and two hex nuts... I keep meaning to hit up someone parting a car for a new one, but I almost never thing about it
