water leak ?
water leak ?
when it rains i noticed some water leaking down into the driver side footwell. could anybody help diagnose this problem ?
1987 951
thanks
1987 951
thanks
Driver side?? I've got water leaking on the passenger side, but have recently been told it's my battery holder. I put an amplifier in and wired it through the grommet hole going to the battery.. well.. that's used for water routing, and when since the hole isn't closed on mine anymore.. water leaks in.. grr...
I'd check around the fuse box area for any rubber grommets that aren't plugged closed.
be sure you vacuum out the water before it mildews!
