FOUND OUT, exactly what I have
I spent a good majority of an hour on the phone w/ 4 companies...
I bought this turbo from SFR.
My wheel measures </font>
With a B housing as people on this board tell me this is.... it's either a Super H or a 60-1 ( if the 60-1 can use the same housing.... ) i do know that 60-1's use a B housing I understand that they hav "1 more fin" on the wheel than other compressors....
how many fins would that mean for a 60-1? I have 7 fins
BUT
WHAT I ordered
</font>
</font>
I would seriously like to get this over w/ and know what I bought... I cause you can order anything you want, but you really dont know what you'll get <img border="0" title="" alt="[Wink]" src="wink.gif" />
SO, i would really appreciate it if somebody could tell me how many fins a 60-1 has.
- <font size="2" face="Verdana,Tahoma,Helvetica">exducers - 3"</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">INDUCER - 2.310ish</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">caliper'd it from corner to corner roughly</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">measured the ID of the inlet and subtracted the gap to the inducer</font></li>
BUT
WHAT I ordered
</font>
- <font size="2" face="Verdana,Tahoma,Helvetica">To4e</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">54 trim</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">#6hotside</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">stage III turbine</font></li>
</font>
- <font size="2" face="Verdana,Tahoma,Helvetica">A B housing....</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">a compressor wheel that flows more air than a 54 trim</font></li>
- <font size="2" face="Verdana,Tahoma,Helvetica">and I talked to a guy that is fimilular w/ Turbo tim's ordering habits....he can't remember TIM EVER ordering a #6 or a #10...., but my housing is FOR SURE a #6. It is not a turbonetics casting and it is identical to my other #6. So i am the rare bird w/ the #6 and it sure does the job great. </font></li>
"Luke, step away from the turbo..."
Yes, and put your hands up and back slowwwwly away making no sudden movements. Do not break eye-contact and no one will get hurt... <img border="0" title="" alt="[Wink]" src="wink.gif" />
I have a 60-1 HIFI it appears only the -1 series turbos have 14fins
T4 12 fins.
<img src="http://store4.yimg.com/I/cheapturbo_1734_328046" alt=" - " />
60-1 - 14 fins
<img src="http://members.rennlist.com/luke/z12.jpg" alt=" - " />
SO i ordered a turbo that could flow 45lbs/minute and got a beast
Am I the only 60-1 w/ a #6?
T4 12 fins.
60-1 - 14 fins
Your turbo inlet appears to have gone dark.
I have the same unit with a #8 hotside and BB. If the !@#$% site would let me upload, I would show you a picture. Case is just like yours, you should find a 60-1 stamp on the outlet tube... were the clamp would go. I was also looking to get a different turbo about the same time you ordered yours, but after a long wait due to vendor supply issues, I was "upgraded"...and I agreed to it. Sounds like it is working for you, it works for me.
Here is the MicroSoft error..I love these.
Database Results Error
[Microsoft][ODBC Microsoft Access Driver]General error Unable to open registry key 'Temporary (volatile) Jet DSN for process 0x4f8 Thread 0x740 DBC 0x1ddc9fd4 Jet'.
My wheel measures
exducers - 3"
You mean your major is 3" right;^)
INDUCER - 2.310ish
it's difficult to measure the inducer, kinda accuratelyhere are the methods I used to measure the inducer
the inducer is CLEARLY in the 2.300 area. +/- 20 thou.
compressors....
60-1 hi-fi uses the B housing. A true 60-1 comes in its own housing that is simliar to the T series housing.
BUT
WHAT I ordered
To4e
54 trim
#6hotside
stage III turbine
WHat I got (love? j/k)
A B housing....
I ordered an E54 wheel which normally comes in a TO4E housing but I had it put in the TO4B housing for you. You might have gotten an upgrade because of the delays we had with your turbo. I can tell you which wheel you got when I get to the shop.
This is because the person I ordered the turbo from no longer works at Turbonetics.I dont always use Turbonetics for our turbos anymore.We have a couple of suppliers so if Turbonetics cant get an order out to us in a timely manner then we go to another shop that can. No more long waits on turbos! Thank God.
It is a 6cm KKK housing that I supplied to you free of charge.
I was told by two sources that a Super H will flow 53lbs/ minute. It looks like abetter map than my 54 trim across the board.
7 larger blades.7 smaller blades
exducers - 3"
INDUCER - 2.310ish
compressors....
BUT
WHAT I ordered
To4e
54 trim
#6hotside
stage III turbine
A B housing....
andy,
the one I have SUCKS, because at the time, I was unaware that the toulene in my tank was throwing off the WB O2 sensor. I'll have a couple good ones in 2.5 weeks.
If i'm right, I should see 320ish @ 18psi with a safe mixture
