Best recipe for finding vacuum leaks?
I don't know if its the best but you can spray starting fluid around the area that you think is leaking...if the rpm's go up then you have a leak because the fluid was sucked into the motor.
The factory manual states a method of cutting a fuel filter in half, installing a valve stem and hooking it up to the intake in place of the Air Flow Meter.
Then you pump air into it and check for leaks =)
