Just about to start up after head removal. What fuses/relays do I remove?
Start up after rebuild. Saw someone say to remove the DME relay and something else fuel related. What are these?
Pull the DME relay and take off the main coil wire on the cap. Crank to build oil pressure.. not really necessary with just a head gasket replacement but good if the car has been sitting for a while.
Ok cool. That's what I did. Thanks for the help. It has turned over just a little low idle with old fuel. Replaced it and now need to look at the balance shafts as it is jumping a little.
