Most powerful 951
#31
[quote]Originally posted by Silverbullet951:
<strong>Wow, so it's fairly easy to hit 350 RWHP on these cars. I think With the map kit by Guru and a new turbo from SFR, new injsectors, that would be good enough for 350 RWHP. What Hp number will you need a stronger clutch?</strong><hr></blockquote>
320rwhp and powershifts will kill the cup clutch using the stock pressure plate. At around 400rwhp, the stock setup will slip and destroy the clutch plate on full throttle. Don't ask me how I know
#33
[quote]Originally posted by toddk911:
<strong>In TURBO magazine a few years ago, there was a heavily modded 951 with the 3.0 motor that was running low 9's in the 1/4. I can't remember the hp, but the phiysics would suggest about 650-700 WHP.
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> </strong><hr></blockquote>
Do you have that article?
If you have can you please "scan" it or something so I can get the chance to read it?!
Regards
Pete
Regards
Pete
#35
Anything is possible, check out the boost numbers, 42.8lbs
<a href="http://www.saabnet.com/tsn/press/020702.html" target="_blank">http://www.saabnet.com/tsn/press/020702.html</a>
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#36
Drive-by provocation guy
So, up to 350 whp with out slicks and power shifting, the clutch can handle it? Is the pressure plate the weak point?
I guess, anyone that is really interested in 0-60 or 1/4 miles, just invest in an upgraded clutch.
#40
[quote]Originally posted by K27:
<strong>Anything is possible, check out the boost numbers, 42.8lbs
<a href="http://www.saabnet.com/tsn/press/020702.html" target="_blank">http://www.saabnet.com/tsn/press/020702.html</a></strong><hr></blockquote>
turbocharged F1 cars use to make upwards of 50 Psi.
highly modified supras make 45 psi i think.
#41
The F1 cars were also running about 90% Toulene.
I was wondering when this additive would come up. It always seems too.
#44
Apparently this 2.0 engine was capable of more, but for reliability they detuned it.
I would love to talk to the guys that built this engine to find out how they achieved these numbers and keep it glued together.
I am sure the same technology could be applied to almost any 4 cylinder engine, but at what point does said engine no longer become the brand that built the original.
So many parts are changed that it really is only the block and head castings that are original.
