LR Radiator hose Question
So, I just reinstalled my radiator and the rest of the coolant system. I replaced all of my coolant lines with the silicone kit from LR, but I'm left with one hose (pictured below) that doesn't seem to have a home. What am I missing? Where does this hose live?
TIA
TIA
Alright, I've looked through every diagram I can find... the one on LR's site, the ones on Pelican and 944Online, even PET and I can't find it... WHAT IS IT FOR????
Thats the turbocharger outlet to turbo auxiliary water pump hose. The updated hose is a 90 degree hose whereas the older 951's have a 90 degree metal elbow attached to the CHRA. So for models with the updated outlet hose you use the 90 degree section of the hose. For early model's you cut that hose and just use a straight section of it to connect the CHRA elbow to the turbo auxiliary water pump inlet.
Oh.. alright then. I think LR has then started to include both hoses in their kits. I got that hose, and a short straight piece, that wasn't pictured but seemed to be obviously for the aux WP. So, I guess I got both?
