Rattling after changing motor mounts
i changed my motor mounts this weekend with the help of Skip (thanks Skip) here in atlanta. one of the original mounts (they were the old green rubber ones) was completely collapsed. i used the OE mounts which were expensive but i didn't want to take any chances. super smooooooth now.
we used the clarks garage procedure which worked but wasn't easy. i can see why most shops hoist the engine from the top a little.
i'm getting a couple of weird noises now and am wondering if anyone can give me some ideas?
1. The torque tube seems noisy now when the car is idling in neutral. it was quiet before and is rattling a bit now. push the clutch in and it stops.
2. When I put the car in first gear and start to let the clutch out it makes some rattling noises like exhaust shield type noise or something.
is there an adjustment with the torque tube? could it misalign the torque tube jacking the engine slightly?
any input would be great.
Hmmm...mine were collapsed pretty bad too. I recall a couple clearance issues after the new mounts were put in. I had them done locally (lister Phlip) and he adjusted a couple things but can't remember what.
I too have the same torque tube rattle (stops with clutch depressed)...and it may or may not have started after the new mounts???
Will be interesting to see the responses.
i need to get back under there and look around to find the rattle but it's tough with one person. plus the rattle is much worse when the clutch is released in first gear so that is going to be hard to replicate.
https://rennlist.com/forums/924-931-...ar-rattle.html
Some people try thicker tranny fluid but otherwise nothing can be done about it. I've got a freshly rebuilt tranny (from kevin gross no less) and it has a lot of that rattle.
the only thing that gives me pause is that I assume you didn't have the rattle before the motor mount job?
The noise for both 1 and 2 sound like classic 5th gear rattle in 944 trannys.
Two things:
If your rattle noise goes away at idle by pushing the clutch in; the problem is very likely the 5th (overdrive gear) rattling.. Very common, and Annoying, but not really a severe issue. I noticed mine after changing to Mobil 1 Tranny Fluid 75w90.
*Recently when installing my clutch i swapped the fluid to Redline MTL for LSD Transmissions , and the Noise is either gone or un-noticeable...
If your noise sounds more like a heat shield rattle the problem likely might be this shield that keeps debris from getting up in your Clutch/Flywheel area..
There should be little dampening pieces that absorb vibration... But they fall out overtime; There was only one left on mine... Everytime I would accelerate a low speeds "Rattle Rattle"
When i did my oil pan gasket i removed this piece, and no more rattle;
If you go to the back of the oil pan you will see it... Black Thin Sheetmetal. Tap on it... it might just sound like the rattle you are hearing.. it's only two bolts... Remove it and test drive..
#27 in the Diagram
Click Here
Hope this Helps!
#27 in the Diagram
Click Here
Hope this Helps!
