My 951 mod story pt 4 - Dyno Day!
Rage... quick question. Am I seeing steam (condensation) or smoke in the dyno runs from your exhaust? Just curious.
Sounds like you are getting there. I was guessing closer to 340 at the wheels myself. I am sure you can get it. Also, if the load is not right, as you said, you will be down on power.
Peace!
Peace!
[quote]Originally posted by IanM:
<strong>I have a manual boost controller on my car, and had similar problems when I put my car on the dyno. Not enough of a load, and even though my controller was set to 16psi, I was only boosting to 14psi. It wasn't really a problem though, I just adjusted the controller slightly during the first dyno pull, to bring the boost up to where I wanted it. After that initial adjustment, it was hitting the boost I wanted, and sitting there right up to redline.</strong><hr></blockquote>
That's effectively what I did by setting the duty cycle to 100% on the AVC-R. The wastegate was completely closed. The spring might be too weak on the deltagate side, but I think I'll just wait for the loaded dyno before doing another run.
[quote]Originally posted by perry951:
<strong>Rage... quick question. Am I seeing steam (condensation) or smoke in the dyno runs from your exhaust? Just curious.
Peace!</strong><hr></blockquote>
It's winter, so you can see everyone's exhaust =). It was about -10C outside that day. There was a bit of smoke on the first run at the end, that was from the tires slipping when letting off, and the dynojet was braking.
I'm aiming for the magical 400rwhp mark. I think I can do it on the dyno if I can get the boost to hold a bit higher near redline. I'm pretty certain that I'm making around the 390rwhp mark on the street at full boost. My boost and torque curve is dropping pretty steep on the dyno, which it doesn't do on the street.
Rage,
It is addictive, while I didn't achieve my previous 330RWHP and only made 320. I going to go up another level. Technodyne is going to install bigger injectors, Mod the MAF, Garret GT-25,Tial WG, and install a Greddy profec-B controller and tune everything. Last night he did a 2.5ltr with these mods and it ran a whopping 400RWHP/420 ft/lbs. That was with alot of boost-110-no pinging!
Paul
Paul
Rage, you install an adjustable cam-gear to combat that dropping torque curve. Retard the cam about 5 degrees and that should help.
You can also adjust the AVC-R to add about 1psi more boost at the higher RPMs as well.
[quote]Originally posted by Danno:
<strong>Rage, you install an adjustable cam-gear to combat that dropping torque curve. Retard the cam about 5 degrees and that should help..</strong><hr></blockquote>
Hey Danno. Do you think it's wise to get an adjustable cam-gear or to get myself a hotter cam instead? Any advantages/disadvantages? I don't have much experience in cam tuning, do I have to worry about redoing my timing curve on either mods?
<strong>You can also adjust the AVC-R to add about 1psi more boost at the higher RPMs as well..</strong><hr></blockquote>
I tried that, definately a load problem that can't be solved until their dynojet is upgraded. At 4500rpm and above I set duty cycle to 100%, boost fuel cut (SDS side) at ~21psi, the boost situation didn't change (the torque curve was a wee bit smoother). After the dyno runs, I forgot to turn the duty cycle down on the street and hit the boost limit fuel cut on the first stretch of road.
[quote]Originally posted by Konstantin:
<strong>rage
your car makes 377 RWP at 20 PSI if everything is tuned properly.
Konstantin</strong><hr></blockquote>
How did you calculate that?
<strong>rage
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
Thank's again for the invite to come out and watch! Snuck out of work for a little while.
As to pinging, I heard no pinging, but then again after three runs I could not hear much of anything!
I have not watched the video, but the drum and tires could probably been a small lose of power as they were both wet. Damn snow drippings.
Any way, talk to you later,
Doug
Doug
[quote]Originally posted by Doug Pell:
<strong>Thank's again for the invite to come out and watch! Snuck out of work for a little while.
Doug</strong><hr></blockquote>
Hey Doug... I think all of us there snuck out from work for a few hours =).
I was in the passenger seat for all the runs, it's a lot quieter in the car. I was told it was so loud on the outside, everybody had to cover their ears. I felt sorry for my brother who couldn't cover his ears, as he was videotaping... he said it hurt =).
As for impatient me, I can't wait for those guys to get their dynojet upgraded, so I ordered a new toy... the <a href="http://www.blitz-na.com/NA_ProductsPowerMeteriD.html" target="_blank">Blitz Power Meter I-D</a>. This thing works like a GTech Pro, except it's more accurate because it reads directly off the speed sensors. What'll I do is do an on road dyno run with this sucker, use my peak tq # from my real dyno run, map the curve from this unit on there, and I *should* be able to get a pretty accurate "on road" dyno (assuming my 404ft/lbs of torque is the highest I achieve on the road).
I think I'll have the thing in a week, of course we'll have some nice pictures and videos of the unit =).
Hey Rage2, do you have the original data files from your dyno runs? I would like to use with my PepViewer software to draw up some comparisons with other cars.
The MAF and the Turbo I have makes 350 @ 18 PSI The Stand alone of rage 2 and more boost should easily make 370+
also if you compare teh power /PSI you make and at which levvel then you can just multiply the more PSI to see the more HP you will get. 370 KP at 20 PSI is very realistic if you have no leaks and teh engine is adjusted properly?
BTW where and how did you tuned the Satnd alone management? Dyno? road? both?
Konstantin
Konstantin
<strong>The MAF and the Turbo I have makes 350 @ 18 PSI The Stand alone of rage 2 and more boost should easily make 370+</strong><hr></blockquote>
Based on races with other high powered friends (I know their weight too) I'm guessing I make around 370rwhp at 5200rpm. I'm getting the Blitz Power Meter or the Racelogic AP-22 to graph a road torque curve to better estimate my power (until the dynojet gets upgraded).
<strong>370 KP at 20 PSI is very realistic if you have no leaks and teh engine is adjusted properly?
There is a small leak right now in the intake gasket, that's getting swapped out this week. Really minor, nothing major. All my tuning have been done on the road. It's the only place I can build up the boost.
<strong>Hey Rage2, do you have the original data files from your dyno runs? I would like to use with my PepViewer software to draw up some comparisons with other cars.</strong><hr></blockquote>
Here you go :
rpm tq hp
3100 161.3 95.2
3200 178.7 108.9
3300 191.5 120.3
3400 207.1 134.1
3500 221.6 147.7
3600 236.8 162.3
3700 253.6 178.7
3800 272.2 196.9
3900 290.2 215.5
4000 303.9 231.5
4100 311.4 243.1
4200 325.6 260.4
4300 362.2 296.5
4400 403.3 337.9
4500 380.0 325.6
4600 361.8 316.9
4700 356.3 318.9
4800 337.3 308.3
4900 345.8 322.6
5000 325.3 309.7
5100 321.3 312.0
5200 291.4 288.5
5300 311.5 314.3
5400 302.3 310.8
5500 291.7 305.5
5600 278.7 297.2
5700 279.8 303.7
5800 267.5 295.4
5900 250.1 281.0
6000 244.8 279.7
Here you go :
rpm tq hp
3100 161.3 95.2
3200 178.7 108.9
3300 191.5 120.3
3400 207.1 134.1
3500 221.6 147.7
3600 236.8 162.3
3700 253.6 178.7
3800 272.2 196.9
3900 290.2 215.5
4000 303.9 231.5
4100 311.4 243.1
4200 325.6 260.4
4300 362.2 296.5
4400 403.3 337.9
4500 380.0 325.6
4600 361.8 316.9
4700 356.3 318.9
4800 337.3 308.3
4900 345.8 322.6
5000 325.3 309.7
5100 321.3 312.0
5200 291.4 288.5
5300 311.5 314.3
5400 302.3 310.8
5500 291.7 305.5
5600 278.7 297.2
5700 279.8 303.7
5800 267.5 295.4
5900 250.1 281.0
6000 244.8 279.7
Rage2,
I am considering Engine Mgmt. in the future and have a couple of questions.
Besides the tuning advantages/less restrictions.
Does the system shut down, have alarm ect.. if you go lean do to a injector failure or something?
Paul
Paul
