Bumper/panel removal question
I posted on the 944 board but thought maybe my luck would be better over here.
I did some searching but oddly enough couldn't find anything. How hard is it to get the bumper and front panel off? A body shop is willing to give me a $400 discount if we take those off to have them painted.
Thanks,
Alex
'88 951 Black - lotso mods <img border="0" alt="[burnout]" title="" src="graemlins/burnout.gif" />
________________________________________________
need time to figure out how to get a signature line.
Thanks,
Alex
Here is a picture of the <a href="http://boards.rennlist.com/upload/Bumper.jpg" target="_blank">Bumper.</a> If you remove the nose panel, use the directions from <a href="http://www.speedforceracing.com/install.htm" target="_blank">SFR</a>, you can see the four bolts that hold the Impact absorber onto the body. Disconnect the electrical connections, skid guards, etc ...then remove the bolts and the bumper is history.
There are only 4 bolts that hold the bumper to the car and they are located just above the side marker light. It's a PITA to get to them unless you have long arms. I think the bolts are 10mm but I could be wrong. It might be better to remove the side marker lights and use a small ratchet through the opening. For removing the nose cover, there is a good writeup of the procedure on the Lindsey Racing website.
Hope this helps,
Dan
Hope this helps,
Dan
