can't remove the power steering bolt
Previous owner rounded out the 6mm Allen head hollow bolt that attaches the high pressure power steering line to the rack from the power steering pump
Not much room there to get any other tool to break it free
Any way to make more room without dropping the power steering rack completely?
Any ideas?
Donn
Any ideas?
Donn
Any ideas?
Donn
Any ideas?
Donn
It helped to have the jack stands all the way up on both sides to get clearance to work on it.
Once you have the steering rack dropped and sway bar out of the way you need to disconnect the clevis fork from the steering gear lower u joint. That is critical to getting the job done. That will allow you to maneuver the power steering up.down , and all around. Make sure you have the wheels off the front of that car BTW.
thanks for the input
does this mean you do not need to separate the tie rods from the steering knuckle?
removing the 4 bolts that hold the rack to the crossmember and the steering gear u joint will free the rack enough to move it?
seems too good to be true- but hope it is
Donn
Donn
