MBC Installation Problems help needed
Hi everybody,
I have recently bought a pair of chips STEVE R, a fabspeed testpipe and MBC.
The chips and the pipe are installed and working pretty fine.
Now I want install the MBC in order to work with my stock wastegate. Does anyone have instructions
Where should i Connect for boost source. what hardware is needed.
THX upfront
951 turbo mod 90
THX upfront
951 turbo mod 90
The factory boost line to the KLR is between the #3 and #4 intake runner. You will want to T into that because the KLR still needs boost signal to control timing. The "out" line from the MBC will then go to the wastegate...
