reassembly of the front of the car! crossmember, p/s, heat shields and vacuum
been busy these past couple of weeks reassembling the front bits of my car...
i got it out of the garage and back in to the driveway, got the belts tensioned, p/s totally finished up and crossmember in, along w/some new hoses, crush washers and fittings: https://lh5.googleusercontent.com/-g...0/IMG_5232.JPG https://lh4.googleusercontent.com/-d...0/IMG_5229.JPG had to fix a line on the reservoir that cracked. a metal fitting and some 10mm silicon tubing later: https://lh4.googleusercontent.com/-w...0/IMG_5238.JPG test fit the intake manifold... looks pretty hawt, imho: https://lh3.googleusercontent.com/-k...0/IMG_5234.JPG reassembled my wastegate w/new hardware: https://lh4.googleusercontent.com/-m...0/IMG_5242.JPG test fitting my heat shields and some of the vacuum system: https://lh6.googleusercontent.com/-e...0/IMG_5244.JPG crossover pipe installed w/new hardware and crush washers: https://lh3.googleusercontent.com/-W...6/IMG_5246.JPG the wastegate and it's piping is being a PAIN to install. i can't get the flared ends on the crossover/wastegate pipe to line up and even if i did, i couldn't get the crush washer in there. guess i'll need to loosen the crossover pipe and start over... sigh. one question: what is this bracket for? i found it sorting through my parts box and i don't recall where it lives and can't find a shot in my old pics: https://lh3.googleusercontent.com/-F...6/IMG_5245.JPG pics of my recent push start here: https://picasaweb.google.com/incompl...99891111564354 |
Is that the rear support for the intake manifold?
That bracket holds together these heat shields and bolts to the oil cooler housing (2 holes, but only 1 bolt goes to the housing.
http://i44.photobucket.com/albums/f3...1/01f5bad1.jpg |
That was what I was thinking. You can see the bracket for the intake in the second to last picture. It looks close, but no cigar. BTW, that shield needs to be installed due to the close proximity to the headers and supported correctly. It will rattle without the proper supports.
hmm. that is a heat shield i don't have... time for more scrounging i guess.
Originally Posted by incomplete
(Post 8718410)
lotsa fun, was that three piece crossmember ever stock...really wish I had one
Originally Posted by spammajamma
(Post 8718722)
Originally Posted by zerMATT951
(Post 8718713)
You're looking for two pieces of shield - it's split in the middle where it attaches to that bracket. There is also one more mount tab on the forward piece where it bolts to the oil cooler housing.
(Post 8718713)
looking good ACE
Originally Posted by Macd315
(Post 8720696)
PITA!! If you forget to install after the headers! Just did this last weekend.
however: i just realized that i used the 'wrong' washers for my headers (skinny home depot ones vs the meaty ones that i just found in my parts pile). i might just take the headers off to facilitate that heat shield install. i already dropped the middle of the crossover pipe to get my wastegate on, so it's not THAT much of a pain in the ass... :\ these cars are hardcore jigsaw puzzles. wtf, porsche! |
Originally Posted by kev951
(Post 8723325)
looking good ACE
trying to drop in the long block on saturday, then off to house hunting I go, for a week to san diego on sunday. Gotta spend another 1k on some last hurrah parts, I totally could have bought some serious property , !#$#%$#%^@$ Can't wait for this car to be "almost done" already!! Me and about 1,000 other people!!! \m/
i'll start posting pics, I am about a year behind
