Damn - Cross Over Crack
Damn 951. I knew I had a leak at my header, was costing me boost. Raised it up tonight to take a look, loosened off all the bolts at the head and crossover in prep to replace the headers. Then I noticed a nice big crack in my crossover pipe. For F__K sakes that is going to add some time to the job.
Any ideas on what to do? I was thinking of getting the Lindsey 2 piece crossover, but they will only modify your pipe now, no core charge, and I'm pretty sure my pipe is scrap.
Whoaaa....Seems karma bit me hard on that one...Picked up 951 from shop today, plan was to repair exhaust leak near wastegate. Guess what, they discovered crack in crossover pipe...
I have been dealing with hesitation and fluctuating boost pressure (When finally boosting after hesitation..), and tractory sounds from that part of exhaust..
I did not know though, that it could make the car so sluggish/hesitating with such a small leak.
Is the crack the problem, or could I have other issues? I have just smoke tested and repaired intake leaks.
Can these cracks be welded if they are small?
Why is it so much extra work if you are removing the headers anyway, chrenan??
I can double check mine when I get home tonight, but I should be able to part with the headers / crosover off my 87 (two piece crossover, but I am keeping the WG inlet pipe)..
PM me if you need a used one, and I will double check them for cracks!
When these things crack where does it occur and how big is it? Can that section be chopped out and replaced by just a regular piece of tubing? Worse comes to worse take it to an exhaust shop and see if they can chop off the merge collector and fab up new everything to the turbo?
Its a crack in the middle of the Y part of the merge collector. And big, was really hidden from view until I got in there wiped things off and took a good look. Then my face did this
The headers aren't terrible to remove, you can back the studs out to make it really easy. The crossover drives me crazy. I've done it twice, once to replace the turbo and oil pan seal, and once to do the clutch. Pulling the intake to get to it isn't terrible I guess, but I hate wrestling with those bolts that attach the cross over to the turbo.
It's a little easier if you get yourself a set of box-end wrenches that both (a) ratchet and (b) can "tilt" the head. I was able to get to them a lot easier that way - mostly from the bottom of the car, thanks to the tilted head.
Something like this: http://www.craftsman.com/shc/s/s_101...ng+Wrench+Sets
I see they have a set of stubbies too.
If everything comes together I should have it up and running for the 29th at stratotech and the PCA event next month, if not I'll have to run the backup RX-8.
It is funny that there is no aftermarket replacement option, its the one pipe in the system like that, everything else you can buy a resonable replacement for. What do the super high horsepower guys do for a crossover, is it all custom stuff?
would be why I have a set available.. no core required.
I got mine second hand, had them shipped to Tim, and had time modify the headers and crossover (Add EGT bungs in all runners, Add ceramic coating, Add T3 flanged up pipe)
there are options!
Higher HP guys use the stage 2 setup that comes with the crosover pipe. and yes Tim can do 16V flanges too!
Wow, that's a slick setup John! Very nice indeed, a little much for me running my little 26/6 and stock boost levels, but I can see how that is the way to go for a well developed car.
