SSI ball joint kit still available?
Hi Guys as the with the title, are the SSI ball joint kits still available? i have tried to email SSI but got no reply
thanks
Sean
thanks
Sean
Looks like 9products just came up with a really nice rebuild kit. It looks cool and apparently can fix out worn out control arms too!
![](http://9products.com/sites/default/files/IMG_0083.jpg)
Just purchased the Rennbay track kit. Better than spending $600.00 otherwise. That now goes with the new 3" garrett Turbo, and Mtune kit. Power, more power.
This didn't cost
me any drachmas
me any drachmas
I had the track kit from Paragon installed on my '86 along with new inner/outer tie rods and saved a lot of $$$. That new 9products kit looks awesome!
It looks like the upper bushing sticks up out of the top of the pocket which would reduce the range of movement in the ball joint. The major problem with stock ball joints, even with their full range of motion intact, is that they tend to run out of room and bind on lowered cars. It looks like these would run into the same problem but on stock ride height cars and would probably result in catastrophic failure on a lowered vehicle.
From the pic they look similar to our track kit but I hope that no one mistakes them for our product, which is available from paragon, 944online, automotion, etc... .
I installed a german made kit to one of my customers 951. This kit was nice, but still i wasnen't satisfied. Talked with my friend Antti who owns 9Products here in Finland. I asked him add some fetures most of the rebuild kits does not have. We studied very closely good condition oem parts, several competititon rebuild kits. Antti told me he can build a kit for me with all the features i asked, from the picture you can see the final version is like factory one.
The range of the movement in the prototype unit is minus 1 degree compared to OEM. The final version that is in manufacturing stage now does allow bigger movement.
Your welcome.
BTW, 1 degree of ball pin travel at the end of it's range is equal to almost an inch of vertical travel at the spindle. It's progressive as the arm leaves the horizontal plane.
Rocket Scientist
