Will turbo S struts fit on an 86 944 turbo?
Yup, they'll fit if you get the entire strut assembly. That's the lower strut-housing along with the springs and upper-perch as well. It's a complete matched set.
I thought that the spindles are different for 87-89? I thought that because of the different offsets between years 86 and late models that I would need the hubs as well?
I am getting the complete assembly but without the lower perch where could I find thenm?
"I thought that the spindles are different for 87-89?"
The spindles are different on the hub/bearing side with a thicker axle & bearings. But on the strut side, the strut-clamp is still the same.
And the difference in offsets is create by a longer A-arm on the later cars.
If you want to run the factory spring, you'll need the factory lower spring perch...I believe they're somewhere around $50 or so. Your other option is to convert to a 2.5" I.D. spring. A lower perch for this setup will run $25 ea.
Your Porsche Parts Superstore
![](http://www.paragon-products.com/v/vspfiles/assets/images/pagidrs2.jpg)
![](http://www.paragon-products.com/v/vspfiles/assets/images/Paragon web logo.gif)
![](http://www.paragon-products.com/v/vspfiles/assets/images/konilogobkbgsm.jpg)
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
