Banjo Bolt?
Banjo Bolt?
Does anyone have a picture of the banjo bolt, and cycling valve, and where they are in the car? I just want to make sure I am looking at all the right things. I am in the middle of a clutch replacement and my wastegate is sitting on my bench, so I was thinking of shimming it 3-4mm. If there is a "jet" in my banjo bolt, it needs to be removed, correct?
Robert
Robert
The banjo bolt in question is the big ol' thing on the turbo to intercooler hard pipe. The cycling valve is a brown and tan plastic cylinder about 2" in diameter and it's under a bunch of stuff at the back of the motor (wiring harness/head heater hose fitting/vacumn lines/etc. Shimming the wastegate would be in conjunction with, not necessarily in replacement of other boost control measures like the banjo bolt jet. Remove it if you're replacing it with a LBE or MBC or EBC.
After 5 days at the Glen I needed some engine work so you are in luck for seeing the cylcing valve. It is normally under the back side of the intake bolted to the bracket: It is the tan and brown item in the middle of the pic:
The banjo bolt is on the Turbo to IC pipe. It is the bolt into the IC pipe with the blue/red LBE attached to it. I held in place where it would normally go...
