DAR: Your Lighting Kit
Well, this is a couple days that I can't send you a response. According to MSN. You are likely out of luck by now anyway, unless you just want bulbs, lenses and the regulator.
People may have cleaned me out of the harness.
Well, no email into my box yet. Let me know so I can figure out where I stand, I think I have a harness left. I also know I have to order more bulbs today.
Dang,
Not sure what my problem is with this board, messages, and e-mail... hopefully I'll figure it out soon. In the meantime, if you do still have a ground harness left, I'd love it. Maybe the best way to connect (until I get messaging squared away) is direct to my e-mail at DARFirewall@comcast.net If you'd let me know exactly what you still have (ground, alt, harness, etc.) and what they cost, I'd appreciate it.
Dar, grounds are no problem. It is the headlight harness that will be an issue. I need to get upwards of 25 guys before I can do another build. I need to order some parts from the old Delco and they don't usually sell in tiny volume. But they sure have some of the best parts on the planet as any Rennlister that has received a harness will tell you.
So, I guess I need to start a list and start taking deposits.
Ice Shark,
My 951 is pretty much exclusively a track car, so lighting isn't an issue. What I'm really after is the ground and alternator (if you ever did that) to clean up the years of poorly done add-on (really bad master kill switch, etc.) Anything you can help me with in those areas would be much appreciated.
