FS 1990 944 S2 Supercharged 968 Engine
What needs to be done well I wanted to polish the cam cover and intake, power steering is leaking- replaced all lines but one ( which is included) and pump, idle is rough-possible due to the cams, not sure blow-off valve is working correctly, suspension can be tuned better I think, starts hard sometimes, supercharger belt can slip but 928 motorsports has a new pulley kit to fix that & get 9-10 psi of boost. Just minor things.
Monkeys Removed by Request
Best of luck with it. A few years ago it would have been a 25k car.
not to thread jack, but consider it a bump...
mind sharing where you picked up both the side skirts, front lip, and headlight conversion?
great overall build, love the exterior combo you went with specifically.
appreciated.
appreciated.
