Modified A Tune - Dyno Results
Sid,
User 1 is AFM voltage. I am not running a PB. I originally was running FQS at position 0 but moved to Position 1 and it is a little rich but safe. Running E85 and the larger injectors exacerbate the variance in the AFM (thus the M-Tune) and I am running on the safe side. The move to FQS #1 was the extent of my tuning. Absolutely no knock at 18 psi.
Small Business Partner
Yep, we typically see a good increase across the board by removing the AFM.
Here is a dyno of the A-Tune vs M-Tune. No tuning changes (besides the MAF code), and these pulls were done within minutes of eachother.
Out of curiosity....is this removing the stock airbox and AFM or is this change from a cone filter fed AFM? Just trying to see how many variables are in play.....
Ya that's a very impressive dyno, even with the A tune and AFM on the car. That's quite a considerable difference from there switching to the MAF as well.
Is that using a k26/6?
The Dyno plot I put up was a K26/8. Peak numbers aside, the interesting thing is the % change across the board for switching to MAF.
Great Dyno! I know since I got my C-Tune Maf setup the car is never felt so good. I have a k27 7200 cold side and I'm almost tempted to just leave the k26/6 in there....almost
