Dry Sump Oil Pump foaming Video
Basic Sponsor
We posted links to 4 videos just received from Dailey showing the difference between a standard oil pump used on a dry sump system and their pump with oil separator being used and the amount of oil foam generated from each set-up.
They had a custom clear oil sump tank made and what you see is something
very enlightening. These videos are not available elsewhere so you're the first to see them. Enjoy!![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
Links are on our Dry Sump web page after the 3rd picture for the top.
View Here
What made sense to get as our optional upgraded pump we offer is now backed up by visual "see for yourself" proof they work.
View Here
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Very interesting video. We always used barnes and aviad pumps on our usac midget, makes me wonder how bad they foamed. I'll have to keep this in mind, at the cost of those motors this is definately something to think about. We've been thinking of building another midget!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Dailey pump is the way to go, I have been using them for a while.
The air / oil separator is very important for several reasons – deaerating the oil allows for putting the oil cooler on the send side (from the pump to the tank). This is nicer than putting the cooler on the pressure side of the pump – better to have no restrictions on the feed into the engine. Also the deaeration by the pump means that you don’t have to rely on the traditional round tank with tangential entry to deaerate the oil – you can go with a much smaller and custom shaped tank.
I learned about the Dailey pumps quite a few years ago from a friend of mine that builds high end circle track engine. The typical dry sump pumps had to be rebuilt several times per year (some of these guys race 3 times per week) but the Dailey pumps were going several years without rebuilding.
Nice stuff! BTW – Both the LeMans GTE class winners used Dailey pumps!
I run the LR dry sump system with this pump and i'm very happy with it .It's a big investment ,but if you look at what you risk on running a high hp engine without a proper oiling system the advantages are realy clear.When i race my car at the track i do not have to worry about oil starvation ,that alone makes it worth it.Working with Mike and Dave Lindsey on this kind of projects makes things a lot easier.
If using the pump with air/oil separator, what size oil tank is required for a 968 with a N/A (for now) motor?
Also, does anyone know of a tank that can fit WITHIN the 968’s engine compartment? Or will the 19x6” 2 gallon silo-shaped Peterson tank fit where the factory charcoal canister is within the fender?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
You could have a tank made in any shape to fit in where you want.
Thanks Chris. What’s an optimal location within the engine bay, based on your extensive experience?
What about having a custom tank built and installed where the 968 air filter box is (if I end up using an ITB system🤗
? There seems to be plenty of space in that general area, though it will place all that weight relatively high up on the car.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
/Peder
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
For street cars - don't worry that much - you cant generate the grip to a point that this matters!
If we are really worried about 'race car type' weight distribution then adding polar momentum is just as bad as raising the center of gravity.....for a full on race car the passenger floor is the best location.
If not to raise center of gravity the drivers side fender could be used were the coal canister sits as suggested by SM. In there a tank can be made to sit very low (floorlevel) kinda like Porsche did on the aircooled 911:s
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I see what you mean but when I thought about that I was thinking a dedicated streetable trackcar that look and work like a stock car with different modifications made in a stealthy manner. Not a full on racecar. But as said just an idea for a custom placement.
