HP Ceiling - 2.5 Litre (std redline/reliable boost level)
In my experience 350whp was right about where what I consider "reliability" started to be compromised in a track setting.
________________________________________________________________________ ______
Yep - I agree Cameron
So long as meth is used as a safety (and not a meth reliant tune) it is absolutely unbeatable. If you do go dry or have a meth system issue you don't blown up
Up to 650hp, generally use a single nozzle setup. When used on a preset psi uses far less meth than most would believe.
I have a single nozzle 100% meth LS triggered at 4 psi. Have used < 4 gallons of meth in the last 16 months. Granted it does not see bad weather or daily use, but is driven hard. In that time it has made a dozen or so passes at the drag strip and 14 standing mile runs, with countless on ramp blasts.
I would have never guessed how little is required to be effective.
Drive-by provocation guy
I don't get why we don't see more meth/water injection around here. Is it because you have to refill it? You can make it where the stuff kicks in once you reach a certain psi, and you don't see full boost for a long duration when you think about it. Running more boost/timing with no downsides, even keeps your internals clean.
Also our wiper fluid tanks are pretty huge if you have the headlight nozzles..
