danno- thoughts on #10 hot sides?
I went to a dyno session(dyno dynamics) this past weekend and there was a David Raines (Powerhaus) built 951 w/3.0 ltr that on the first pull made 493WHP. I believe it had a K29. The car looks awesome and is going to be raffled off for $100 a ticket for charity. The owners name is Joe Cervantes(SP?)??
I think David said his pulled 430WHP at low boost probably with tons of trq.
Paul
Paul
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by KokelnRob:
<strong>P-trim on a 16V motor would be a good size due to the greater air flow of the head. It would be real lazy and have a lot of lag on a 8V motor.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">rob...regardless of housing size? would it work better in an 8 hot side? what t04e compressor wheel would you be inclined to match to a motor of this displacement?
A larger wheel in a small housing is not doing anything to help the back pressure problem. Sure you may have faster exhaust velocities but there would be a lot less volume going through the housing due to the larger wheel. A displacement increase from 2.5 to 3.0 is going to cause an increase of roughly 16.7% more exhaust that needs to pass through the turbo. If there is already a delta pressure imbalance, this is going to make the problem worse. If the back pressure is too high, you may lose hp.
A good T04E wheel for this set up would be the 60.
