A- Arm effect corner balance
I don't know if the firehawk strut is adjustable for ride height, but if it is, your corner weights should only change if you adjust the ride height. If you simply disconnected the strut from the spindle you shouldn't need to corner balance again.
You should not need to do anything. The A Arm is connected at 3 points, excluding the sway bar. The only thing you might possibly mess up would be the Castor but that is not a real big issue. Simply unattach the sway bar from the A Arm, remove the pinch bolt at the spindle / ball jopint connection first as you made need a mallet to persuade the ball joint to come out. Mark the eccentric bolt, remove the rear mount, remove the bolt in front and the assembly should fall out in your hands. reverse the process putting it back on. No alignment really necessary as you haven't messed with any of the settings. No need to re-corner balance as again you have not messed with anything that affects ride height.
Takes about 1/2 hour if you have everything you need, an hour or so if beer is involved.
Like the wheels!
