Cams?
Depends upon what level of mods you have in your car. Cams would be one of the last upgrades after chips, boost-controller, free-flow exhaust, MAF, larger-turbo, aftermarket EFI & MAP, head porting&polishing, adjustable cam-sprockets, then cams. Kinda follows a bang-for-the-buck or HP/dollar-spent type of progression...
[quote]Originally posted by Danno:
<strong>Cams would be one of the last upgrades after chips, boost-controller, free-flow exhaust, MAF, larger-turbo, aftermarket EFI & MAP, head porting&polishing, adjustable cam-sprockets, then cams. Kinda follows a bang-for-the-buck or HP/dollar-spent type of progression... </strong><hr></blockquote>
Damn, I'm almost at the end of the list =).
Rage,
I have been considering a cam upgrade but have not seen any results posted.
What kind of cam are you going with? numbers? Also what kind of perf. numbers are you running 60? 1/4? Just curious my new set-up should produce simular hp/torque results.
Paul
Paul
