Vitesse AFM Chip Questions
- No it does not ignore the O2 sensor.
- There were different variations of the K26/6 chip, follow the recommended boost which is specified in the instructions as supplied with the chip.
- Do not care about KLR chip. Ok to use stock one.
Anything is possible, but why? It will be static, so every time you need to change the boost curve, you have to reprogram the chip. We have a better way to control boost via the CV, where the user gain full control of the boost curve..
