Rear Wheel bearing replacement
Since my rear wheel bearings are making a hell lot of noise, I figure they are basically shot. Is replacing them a big job? What is needed to do the job right? I hear that I need to use a press in order to get them out. Where can I get a set for a good price? Thanks guys.
I am doing mine Tuesday, and I will do a write up with pics.
I have been told a puller/plate assembly is easy, and also using 2 propane torches and a drift makes things easy.
If I can get the plates, I am going that route, if not, torches will have to do.
Check back Wednesday afternoon.
I also hear a squeak when I'm in reverse, but I think that's something else. When I drive, I hear a very loud "wub-wub-wub" sound coming from the rear of the car. Plus, when I pull the car to the left, the right rear seems to start with this VERY LOUD whining noise ( whines only when under load) that doesn't go away until I come to a full stop.
Perry, How many came in a box? Did you have to buy them seperately? Thanks guys.
