The car is in the shop.
The 951 is in the shop to get the powerhaus head put on. While he has it apart it will be getting all new belts, rollers, water pump, hoses, vac lines, and cam gear cover(mine has a whole in it from when the timing belt broke, how you ask, I will tell you how. The belt broke because a bolt flew into the belt cover through a small hole in the back cover. It stopped the gear, or broke the belt, after rattling around in there, and it cracked the cam gear cover.)
Anything else I should have done while he has it in there.
Thanx
-John
Thanx
-John
Check the vacuum line under the intake, if they are original, they are hard and cracked and should be replaced. Also replace the heater control valve and the hoses to the heater (cheap parts). You can get at them with the head off and if they start leaking, they can ruin a clutch.
