Aftermarket Piston Size and Durability
Hey guys, i kinda had a post about this the other week but im still lost.. Im replacing my rods and pistons and doing all the head work and crosdrilled crankshaft.. i want an extremely durable engine.. I know which rods to get.. but as for Pistons and Size.. Im confused..
I know JE sells excellent pistons.. but do they need to be Iron coated or what size? can you go bigger than factory? I mean, im in the market for the best possible type.. ???
"Their aluminum pistons likes to ride against steel/iron, hence the sleeves. Our Porsches are the other way around with aluminum bores which requires an iron coating on the piston itself."
what will i have to do about this exactly?
thanks
Rambino
thanks
Rambino
Still confused. What kind of motor are you building (street, hot rod, track/race)? What type of performance are you looking to get? The fact that you are considering aftermarket rods seems to indicate that you are building a serious motor.
The factory Mauhle pistons are very strong and were designed for longevity and durability. The JE's are a lot lighter but a little more suited to racing or high performance applications.
