Turbo hotside flange seal - how to remove?
Is there any trick to removing the o-ring flange seal in the turbo hotside outlet pipe? Mine seems permanently stuck in the housing.
Tried a few of the shop picking and prying tools without much luck. Being gentle at this point.....
Thanks.
Thanks.
I just did this today with the two near the wastegate. The first one I picked and pried at (which made it worse), ultimately going to a dremel to cut it and break it out. The second one I heated with a torch and tapped with a screw driver and it popped right out. Surprised the crap out of me.
So yeah, what Brian said.
