Loud clicking coming from rear of car when clutch is engaged
I searched the forum to see if anyone else had a similar problem but only found topics involving the CV Joints going out and nothing about this sound while the car is just sitting still.
I am having a really loud clicking sound from the back of my 86 944 Turbo when the clutch is engaged, the sound goes away when the clutch is dis-engaged. I'm thinking possible throwout bearing is gone or about to go completely but I am unsure as I am a bit unfamiliar with the drivetrain setup on these cars (engine in front with trans in rear).
I have a video of the car at idle sitting in my driveway with the clutch engaged below. Any input is appreciated, thank you.
http://www.youtube.com/watch?v=FGvsA7MRDiw
I was thinking TT bearings as well, just because that's about the only thing moving besides the input shaft of the transmission. Since you said you weren't that familiar with the setup, TT= Torque Tube, it's what sits between the back of the engine and the transmission. There are 3 or 4 bearings in that tube that support the driveshaft.
How many miles are on the car?
To replace these bearings, I assume I just unbolt CV axles, drop trans, unbolt torque tube and press them out? Or would this require a replacement of the entire torque tube assembly?
Mine has 200k on it. I maintain a friends very nice 86 Pearl white W/63K & it clicks. Check out Clark's Garage for procedure to remove TT. You have to drop rear suspension to get it out. Replacing bearings is not hard or expensive if the bearing carriers are in good shape. You can make the tool to remove /install from allthread rod @Home Depot for about $15.
Ahh, well thank you! From what I've gathered, these bearings are of the same size and will work for replacement? http://www1.mscdirect.com/CGI/NNSRIT...PMPXNO=3441701
Unless you can recommend something better that isn't the "Constantine's Torque Tube Bearings" as those are a bit far out of my ideal budget on replacing the torque tube bearings considering the car I have has very basic mods that would make those complete overkill.
Oddly enough I actually look forward to tearing into this project as this is the first major work i'll have had to do to it
