rebuilding idle compensator ??
Has anyone disassembled the idle compensator to clean and replace any seals??
Mine is working fine but has a small vac leak around the body and the elect connection.
Mine was leaking the same as yours. On mine, instead of disassembling it, I JB-welded around the body and connector. This stopped all the leaks and the valve still works properly.
Rob
Rob
