Boost question
Boost question
I am running 12psi in 1and2 gears and 14psi in the the rest of the gears. Will the stock chips send enough fuel for this?? I dont want to run lean. Also I live at 6300 ft. above sea level and have the reliaboost II so I could dial it down if I had to.
You are probably fine...
14psi at 6300ft is probably putting out as much power as 10psi at sea level. Give or take a bit...
Wouldn't hurt to throw it on a dyno with a wide band to check the A/F ratio though. Added bonus of figuring out how much HP you are making.
-Matt
-Matt
Yeah I would like to take it to a dyno. But I am selling my other 944 this next week so I will have some money to get a A/F meter and wide band O2 sensor as well as GURU map 1 or GURU chips
That's cool... I've been looking in to a wide-band kit as well. Haven't decided on the DIY kit or something like the one Lindsey sells.
I've got the Guru Stage 2 Map kit and its a nice improvement over stock.
-Matt
-Matt
