What oil filter(quick)
I haven't been able to get a manual for this car yet ... I'd really like to change the oil and filter this morning.
What brand/model filter does this take?
How much oil is added after draining?
Where approximately is the drain plug located(in case it's a little obscure)?
THANKS for the quick help! <img border="0" title="" alt="[Wink]" src="wink.gif" />
Hey there
Mahles are the respected standard, only $4-5 ea. from Paragon Products so get like 3 in your next order to them
In a pinch, most quality auto parts stores stock Mobil 1 filters or Bosch filters. These are OK.
Say NO to Fram!
The drain plug is pretty obvious - on the passenger side of the oil pan. after the large-but-thin alluminum under-engine protector is removed (If you car still has one).
Fill new oil to the mark and rn for 5 mins. Lt set for atleast 15 mins and check level again.
Look up the archives, a few messages on the board have covered some of the details like how to get the old filter off w/ out oil all over the engine/ground. Some people puncture the top of the old filter to let the oil have a chance to drain out the bottom before removal, some use plastic bags.
Hope that helps.
Matt
Say NO to Fram!
Hope that helps.
Matt
Only one choice, in my opinion... Mahle OC-142. Ian Riley at Europarts (954-968-3766) and Jason at Paragon will get you taken care of in a jiffy, and both sponsor Rennlist, so give 'em your business.
Regards,
Regards,
sorry folks, didn't mean to intro tweeks and perpro, i wasn't aware of mahle. what makes it good. also i can only get fram on base. but ty for the info and in the future i'll be getting it from paragon.
Correction:
Turbos have a large black plastic engine tray in front of a thin alluminum one, I was thinking "NA" when posting this morning.
Bad dog! bad! . . .
Bad dog! bad! . . .
Any import to the alum. undertray(aerodynamics, etc)?
I don't have one ... as I noticed when replacing my wastegate(2hr beginner job my bum ... maybe a beginner with 3 friends to pry stuff and a oxygen/MAP gas torch ...) <img border="0" title="" alt="[Wink]" src="wink.gif" />
Yeah, hee, hee. . . wastegates - or any part of our exhaust systems - dont come off easily. It's enough to drive a man to buy a heliarc welder and tubing bender just to have an easily serviceable exhaust. In the mean time there's always Tim Richards for hire. That and a can of PB Blaster goes a long way
Re: engine pans. They do make a difference both air-flow wise and protection, how much difference is arguable. I know the most significant on a turbo-car is the front nose undertray - it is a big benifit to radiator airflow. The further back you go, the less important - in my opinion. I keep the middle plastic undertray and put it on/ leave it off intermittantly. The rear alluminum one, ebayed that baby!
FWIW, the black "factory" filters with the Porsche script sold by dealer parts counters here in Europe for $14/ea are "Made in U.S.A." and are probably the same "Deutsch" brand filters you can buy at Autozone for under $5. <img border="0" alt="[grrrrrrr]" title="" src="graemlins/cussing.gif" />
