rain weekend what to do...clean grounds...but where?
It probably was a few degrees cooler in the garage...maybe 8-10c I was not sure the minimum range of the sensor and if my reading would be in range for those temperatures. I will have to check it out again when it gets warmer out. I was hopping that that would be my problem because if that isnt it then I dont know what else would be my cold start problem as it runs fine when warm.
Going to reset the idle as I did find that screw loose. I doubt that is my only problem but a place to start.
Also noticed my clutch master seems to be leaking a bit under the dash. Rear seal? Are seal kits available for these or does the whole slave require replacement?
