Anyone have a sequence(Build) order for re-installing Front Suspension
A Arms are already installed ( never removed)
I was thinking ...???
1- ABS sensors on Spindles
2- Spindles
3- Tie Rods ( connect to Spindles )
4- Brake Disc Shield Plates
5- Struts ( connect to spindle )
6- Bearings and Hubs
7- Brake Rotors
8- Brake Calipers
9- Brake lines and ABS connected
10-Sway Bars
Please give me your take on this...
Thanks in advance guys
Regards
Ed
2- Spindles
7- Brake Rotors
8- Brake Calipers
10-Sway Bars
Regards
Ed
I believe the way I did it was:
1 - Install control arms (You, of course, don't have to)
2 - Install spindle onto control arm
3 - Install strut and attach to spindle
4 - Attach tie rods to strut
5 - Install brake shield
6 - Install hub, set front wheel bearings to spec
7 - Install brake disc
8 - Install caliper
9 - Connect brake lines and install ABS sensor
10 - Connect sway bar
If you like you can give me a call and we can talk about it over the phone.
Good luck!
8 - Install caliper
Good luck!
8 - Install caliper
Good luck!
8 - Install caliper
Good luck!
Regards
Ed
8 - Install caliper
Good luck!
8 - Install caliper
Good luck!
Have fun.
Jason
8 - Install caliper
Good luck!
8 - Install caliper
Good luck!
.1 - remove control arms
.11a -clean/plate/coat everything to better than new within 1 foot radius
.1a- replace ball joints
.1b - bead blast control arms
.11a -replace busings in control arm
.1c - clear coat control arms
.1d - have torque wrench calibrated
1 - Install control arms (You, of course, do have to this)
1.05 -touch up scuffs on fasteners after torquing
1.1 -remove control arms
1.2 -strip clear coat
1.3 -reapply clearcoat to improve match with nearby parts
1.4 -reinstall control arms
1.45 -get offspring off the video games
1.5 -repeat step 1.05 as needed
1.6 remove castor blocks
1.7- search internet for cheapest 968 caster blocks
1.8 -install 968 caster blocks
1.81 -repeat step 1.05
2.05 -repeat step 1.05 as needed
2.06 - repeat step 11a due to passage of time
2.1 --assemble strut with better than new anodized and painted parts
2.15 -repeat step 1.45 damn it
2.105 -touch up spring scratches after using spring compressor
3.05 -repeat step 1.05 as needed
3.06 -agonize over appearance of control arms
3.07 -say screw it and repeat steps .1 through 1.05
3.08 -search for castle nuts at your lady friends' store
3.09 -take break and dig moat around house with hand trowel in middle of summer
3.10 -set tie rod ends for approximate alignment
4.05 -search to identify purpose of yardsale tool
4.1 -have new castle nuts plated and "prepared" using proprietary coating technique that I will take to my grave
4.2 -touch up brake shields since their last prepping
5.1 -repeat step 1.05 as needed
5.2 -repeat step 1.45
5.2 -do woodwork for needy friend
5.3 -confirm previously replaced bearings are still ok
6.01 repeat step .11a
7.1 -repeat step 1.05 as needed
8 - Install the world's best looking powder coated caliper
8.1 -repeat step 1.05 several times
9.1 -bleed brake fluid
9.2 repeat steps 1.45 and .11a
10 - Connect the world's best looking sway bar
10.1 repeat step 1.05 as needed
10.11 repeat step 1.45
Hey Darwin
I thought so ...
It's going,.... but slowly. I think I took the MAF off no less than 15 times The manifold 5 times
The modified turbo Y water pipe 20 times
Yada Yada Yada ...
LOL ......
You got the repeat part down ... that's for sure
I thought so ...
Yada Yada Yada ...
Your list looks fairly accurate, but I corrected it below for Crazy Eddie's purposes:
I knew I could get a laugh this morning! Thanks Tom!
Ed, most of us go through a fire drill much like Tom describes in his service manual addendum. Hopefully yours will go together without fanfare.
