86' 951 ball joint replacement. Bolt in or replace the arms?
I have and 86' 951 and one of the ball joints has some play to it, Can I just get a new ball joint and bolt it in or am I looking at replacing the whole arm?
Omniphil...fresh off the 924/944/951/868 board:
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=15&t=010756" target="_blank">http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=15&t=010756</a>
This will get you started.
Mike
Mike
Former Sponsor
It's a bit more than "bolt in" procedure. You can get replacement innards (I'm actually working on some now). Mostly, it's the bushings inside that wear out and break with the actual ball part suffering little if no wear.
