320 rwhp goals?????????
HI,,,
I ve decided on a garret turbo charger, no i need to know what size would be appropriate. Turbo Tim's stage one really cought my eye because it sits right @ my goal hp level and is pretty cheap. His stage three on the other hand will give me my 320whp goal at lower boost levels...(compensating with an increased boost threshold> )
so my question is ... "would it be better to install a
smaller turbo that spools quick but makes 320 @ 19lbs . or
A larger unit that will make 320 @ 14 lbs?
I am being told that the larger unit with a 3 in. inlet will make full boost @ around 3000rpm.
n/e opinions or personal expireinces would be very much appreciated.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
My relatively simplistic view..
Less boost/colder charge = Engine last longer
My 951 doesn't hit full boost till 3500rpm or thereabouts...tip in at 2500. Thats with the stock K26/8 and jetted banjo bolt.
Thank you all very much, that was what i was asuming.
adrial, Do you have a MAF? I dont and my 26/6 makes full boost @ 3000. Do you have an aftermarket wastegate or exhaust?
Sorry...missed your questions Luke...
Nope, no MAF, no exhaust no nothing except chips & banjo bolt.
Full boost at 3500rpm...
Keep me posted on the MAF you're getting, if it works well I'll push that up on the list...For $1500 I wasn't about to get a MAF, but for $600...hey why not?
