spark plug heat range
Curious as to Spark plug brands and heat ranges that are used by 951 Pilots out there.
Heat ranges of Stock/hotter/colder and why ?
Thank you very much
Thank you very much
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Eugene-
I use good old copper plugs in my 951 race car (NGK ... I like their quality) and inspect / replace them frequently.
The NGK Tech Guy told me to run 1 to 2 plugs colder because of my mods. Currently running 1 plug range colder. I may try 2 plugs colder but don't really have a compelling reason too ... everything is working great.
MODS: MAF / Custom Chips / Group A turbo / Godzilla Blow Off / 20-21 lbs. peak boost / true seal rings / stock waste gate with LBE cranked! (~17 lbs.) / 110 octane race fuel ...
I know I'm gonna get crap about the max boost ... hey what can I say ... 4+ seasons now with stock head bolts too!!!! Go figure (knock on wood)
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Hey man nothing wrong with that boost level. The problem is really with maintaining the proper air:fuel ratio (12.5:1 makes most power). Rodney Wiggins recently built a 400rwhp 951 using 25psi of boost and a completely stock bottom end. He's got stock pistons, so I guess it's still the same 8:1 compression.
