re spray wash engine problem??????
thanks to all the guys who responded earlier you are true porsche nuts, but now when i tried to crank my baby up it will not start again check the tps and the plug has no water pull the distributer and dried it still no crank but i notice from the spark coil that i was getting fire but none from the individual spark plug meaning when i pull the plugs for the spark plug there was no juice but the coil is giving it fire i know shock the h@## out of me so guys what the heck is the problem?????
racer x
racer x
Did you get your distributor cap on good also did you take your rotor out when you dried it out if so make shure it's turning when you crank the car over (I had the little allen screw come out of mine while driving)check those if your are getting fire from the coil, that's the only thing I could think of that would keep you from firing.
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
what does it sound like? Does it just turn and turn... are you sure its spark you need and not fuel? Makes sure you did n't short something that may have in turn blown the fuel inj. fuse
sorry i just hate that feeling when a car doesn't start.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
