Zeitronix Harness Flaw?
I'm upgrading to the 2010 version of the Zt-2. The online instructions (and my old harness) have the orange wire in position 4 and the white/blue wire in position 5. However, my factory new zeitronix harness has those wires backwards?!?
Sent a note to zeitronix just now to check, but thought I'd ask if anyone here has come across this?
Tom, They changed the firmware not too long ago (in the last year). Not sure if they changed the harness pin out or color scheme.
They should have a table describing the pins and the associated color for your unit.
Thanks. Their online wiring chart for both the old and new versions both show it the same -- Orange in 4, White/Blue in 5. That is how my old Zeitronix harness is set up also. For whatever reason, my new harness has those two switched. I assume they just plugged them in wrong, but hate to wire it up without knowing for sure. As it is, I already wired up their boost sensor (probably incorrectly, since I used the color without realizing it was in the wrong pin) and used a loom cover and adhesive lined shrink tubing...
Just checked a new harness, it should be the latest as of late last year.
#1 - RED
#2 - White
#3 - Green
#4 - Orange
#5 - White/Blue
#6 - Yellow
You can swap the pins in the plug. Use a needle to remove the pins.. Still a PITA
#1 - RED
#2 - White
#3 - Green
#4 - Orange
#5 - White/Blue
#6 - Yellow
Thanks for checking John -- above and beyond the call of duty once again! Your list is consistent with zeitronix website and my old harness. I actually have the official molex pin puller for these connectors, but I've found it tends to reduce the pin-holding ability of the connector (probably wear/scrapes away the ridge for the pin tang). I'm trying to eliminate all little wiring gremlins, so would prefer to just get a new one I think. The orange wire is already sealed in a loom with adhesive line shrink tubing, so would be a pain to recover from there. Raining too much to drive the car anyway -- need and Arc to get around... This may be the longest one-afternoon job yet. Here's a picture of the harness with the wires apparently switched at birth...
A trick for keeping the pins in the connector would be to add a little hot glue to the side that receives the wire. Still kind of sucks with a new product. Maybe have Zeitronix send you another and keep it somewhere safe in case of any trouble in the future?
And if the solder joint isn't going to to be seeing any moisture adhesive lined heat shrink is kind of overkill, granted I'm guilty of doing the same thing from time to time just for peace of mind.
You may be a valuable one off, like the inverted Jenny LOL
http://en.wikipedia.org/wiki/Inverted_Jenny
That just sold for almost 3 million
Sorry about the problem though ....
And, for the record, "overkill" is my middle name.
Well Zeitronix got back to me first thing this morning and confirmed the wires were reversed by mistake. They are taking care of it right away with a replacement harness, so special thanks to them for that!
There is one difference in that the pin for the user2 input should have a white/blue wire on it instead of gray. The User2 input is new for the 2010 Zeitronix. Comes in really handy for measuring fuel pressure
