Need help w/ size of fitting on oil filter housing
I appreciate any help w/ the size of the fitting on the front of the oil filter housing facing the front of the car, directly under the lip for the base of the oil filter.
I tried to remove the male to male adapter in the block to bring to dertermine, but w/ the engine in, I can not get it loose w/o getting out the impact, and I am concerned I may have trouble getting the AN fitting tight enough. Also I can use the adapter the help offset where I want the oil line to be.
I just need to know the male fitting size that is exposed when the oil cooler hose is removed, not the male size in the block.
I looked through the archives and saw mention of a size of 22 x 1.5 but was not sure if that was the male adapter in the block.
Any help would be appreciated, I was hoping to order today, but tommarrow may still get it to my by Fri.
Thankyou for any help.
Steve
Steve
