Best price on 55 lb injectors?
Ballast resistors are about $5 or less each. You need 2 of them. With the Siemens (2.35ohm) you can use 1.35-1.5 ohm (10W) resistors. It's a good idea to mount the resistors on a piece of aluminum to act as a heat sink. Get the Aluminum housed wirewound resistors. I personally never used the resistors and never had a problem. But you decide if you need them on your own.
Stephan,
I am still waiting for my GURU chips so have not run the car and have not considered using the ballast resistors at this point. I am not sure if they are necessary.
I noticed you have a 940 turbo, can you recommend any one for parts on that car?
Basic Sponsor
I ordered 55 lbs injectors from Lindsey on Tuesday, and I was told by Dave Lindsey that there is no need for any ballast.
Blitz, I can hook you up with just about everything you need on the Volvo. Send me a list of parts and I'll supply you with some prices. I ran the Gtech on my Volvo last night best run was 15.91 @ 87.8 mph.
Stephan,
sounds like a good run for the swedish tank <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" /> I dont need any parts as of yet but when I do I will talk to you, thanks.
ringo951, I've used those exact same Siemens injectors on my car when I had my MAF-4 kit a couple years ago. Aside from my DME getting quite hot at the track, they worked just fine (didn't know about V=IR back then).
When I started programming chips later, I realized from the mappings I had to do that injectors are not linear devices. Their flow-ratings are tested at a static-flow setting of 100% duty-cycle @ 3-bar pressure. However, when you're using 3% at idle, 10-50% driving around and 60-90% under WOT, the actual flow doesn't scale linearly with duty-cycle.
The Siemens with the ball-end function similarly to the Bosch injectors at idle. But they had a little less fuel than the Bosch at higher duty-cycles (both inject less than computed theoretical amount at higher duty-cycles). Our Dephi units with 6 holes tended to be a little richer than the computed amount compared to both Siemens or Bosch at idle. But they scaled up more linearly which made the chip-mapping easier. As an end-user, I doubt you'd notice any differences (just remember V=IR).
Originally posted by Danno
[B][i]"One things I have to distinguish is that all the Rochester injectors (and their re-badged MSD counterpart) are high-impedance injectors.
I am going to go for the Racetronix Simens injectors. Though I am not sure about running ballasts or not! Some so yes some say no... While running a Link2, whats the go?
Will these injectors work with our cars. With 3 bar FPR will that be about 55LB?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33554
