Engine Cut off at 4K rpm
Old 05-07-2003, 07:06 PM
Martindup
Martindup's Avatar
Post
what I need to check
Old 05-09-2003, 03:05 PM
Martindup
Martindup's Avatar
Post
I try the tps sensor and it not that I need to try an other sensor for the turbo just under the intake
Old 05-09-2003, 03:30 PM
Martindup
Martindup's Avatar
Post
I try the tps sensor but it not that and I need to check someting else, sensor or valve under the intake just beside firewall
Old 05-09-2003, 03:47 PM
dmoffitt
dmoffitt's Avatar
Post
I ran into the same thing w/ my previous car (86) - was the overboost protection. get a set of guru chips, you won't look back. i would also double-check the functionality of your AFM (meter the voltage) - I'd request the shop who did the original work for you do this, at their expense, and that you be present during the service... it's easy to do yourself, but if they caused the problem, they should fix it.
best of luck <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Quick Reply: Engine Cut off at 4K rpm
