Dodgy Rad Fan
Dodgy Rad Fan
My radiator cooling fans have started to continuously cut in and out. Once the car has warmed up the fan cuts in for a couple of seconds then turns off for a further couple seconds before starting again. I've changed the sensor/switch in the radiator and its made no difference. Has anybody else had this problem??
Seems normal if I understand you correctly. However you know what is normal for your car. My problem that I experienced was that the fan would stay on and not cycle on and off. The problem was the relay. I tapped on it and it would start working again. Try the relay. New ones are expensive however. Cheapest I saw was $95 plus shipping.
