Does the 951 have that oil/water oil cooler separator
You know the thing on the side of the motor that is a oil/water seperator/cooler that is supposedly notorious for leaking??? Well, does the 951 have this as well? I am trying to determine where a leak on the right side is coming from. Someone told me the 951 does not have this. this is why they have the external one that is down low on the right side of the radiator. I did the belts and seals 5 weeks ago and no seals were leaking. It aint the oil pressure sender either. It is definitely oil, its not red.
The 951 does have an external oil cooler that is mounted in the front, below the bumper, but the oil/coolant housing is the same as in the N/A cars. Instead of the actual cooler being in the housing, there are two tubes with o-rings that seal the oil tubes going through that housing to the external cooler.
Hope that helps!
Dal.
Hope that helps!
Dal.
