Compression Test
Old 05-05-2003, 05:00 PM
Dan87951
Dan87951's Avatar
Post Compression Test
Where should the compression be on a healthy 944 Turbo engine (non S)?? If I remember correctly last year I got around 135-137psi across the board.
Old 05-05-2003, 05:01 PM
Luke
Luke's Avatar
Post
i saw 148,145,144,145 last week.
Old 05-05-2003, 05:20 PM
Chas
Chas's Avatar
Post
The manual states 10 bar, or 145psi as a lower acceptable limit
...on a 16+ year old car, 145's across the board would be more of a perfect score than a lower acceptable number
Old 05-05-2003, 08:21 PM
adrial
adrial's Avatar
Post
If you do it warm, 140-150 is normal.
Though just as important as that is that all cylinders are nearly equal..with 10-15% between them as a maximum.
Old 05-05-2003, 08:51 PM
Perry 951
Perry 951's Avatar
Post
125 is low, 160 is high on a 90k motor. Again, most important is the differential in the numbers across the cylinders.
Old 05-05-2003, 09:07 PM
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Post
Here's something guaranteed to screw you up.
Do a compression test on a car with a big cam!
I almost died when I got 115psi across the board!
The I remembered the big cam!
Talk about a scare!
Old 05-05-2003, 09:13 PM
Mike B
Done With Sidepatch
Mike B's Avatar
Post
I did mine last week on a rebuilt motor with about 900 miles on it...It was 130, 125, 130, 130...Not sure about my gauge...The thing runs flawlessly.
Old 05-06-2003, 04:25 AM
dmoffitt
dmoffitt's Avatar
Post
my old motor had 151 152 135 150. a big "uh oh" light should have gone off in my mind... hmm, and guess which cyl. was the "problem" one not long thereafter?
Old 06-22-2004, 08:32 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Just did mine on warm engine (but not a full operating temp) and not sure how accurate the guage is.
120, 129, 135, 128
A little low or just becasue not at full operating temp?
Old 06-22-2004, 08:40 PM
Jfrahm
Jfrahm's Avatar
How do you test the turbo motor's compression, pull the IC pipe off and pin the TB open?
-Joel.
Old 06-22-2004, 11:02 PM
Danno
Danno's Avatar
Pull all the plugs and insert compression-gauge (pressure-gauge). Basically 0-200psi gauge with a hose hooked up to it with threads that matches the threads of the engine you're testing:
Snap-on Compression tester
Star Compression tester
S&G Tool Aid
Old 06-22-2004, 11:24 PM
Bryans951
Bryans951's Avatar
I got 160, 155, 155, 160 when I did mine.
Old 06-22-2004, 11:37 PM
Jfrahm
Jfrahm's Avatar
I understand you should keep the throttle wide open to get accurate results, but what about the AFM, turbo, etc?
-Joel.
Old 06-23-2004, 01:41 AM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
I remember getting between 145~150 on all cylinders, the car wasn't fully warm, it was sitting for 30~45 mins after driving for a while. Which i guess is a good engine? but i need a leak tester though.
Old 06-23-2004, 12:04 PM
toddk911
toddk911's Avatar
Oh crap, I didn't have the throttle wide open.
How much difference does that make?
Quick Reply: Compression Test
